Updated De-Clicker and new De-esser for speech
It is there it is there… Oh my goodness… Thank you Steve… Any advice on the best settings to use when editing?
Hooray :smiley:
Well done. So pleased to hear.
Not from me, I’ve never used the effect, but Paul (who created the plug-in) wrote some documentation of sorts here: Updated De-Clicker and new De-esser for speech
I’m soooooo relieved… Thank you again so much!
Hi. What’s the newest plug in for de essing? I downloaded a file from this thread called “DeEsser.ny” but it won’t open.
See here for how to install Nyquist plug-in in Audacity 2.3.2 on Windows: https://manual.audacityteam.org/man/installing_effect_generator_and_analyzer_plug_ins_on_windows.html#nyquist_install
If you don’t have Audacity 2.3.2, you can download it via the Audacity website: Audacity ® | Download for Windows
Thanks, Steve. I run the portable vesrion. Last time I installed a plug in file, I did it by copying it directly into portable. But that was a VST plug in.
This seems a bit buggy on 2.4.1. The progress dialog no longer shows… Any ideas why this may be?
Are you running the effect in a Macro?
Yes I am! It shows a progress meter using the normal non-macro method… This used to work fine on the older version, any idea how this can be fixed?
It’s due to a bug in Audacity. I’m hoping it will be fixed in the next release. The bug affects all Nyquist effects when they run in a macro, but most effects are a lot quicker than the De-Clicker / De-Esser so it’s not noticeable unless processing very long tracks. The problem was first spotted with the De-Clicker shortly before Audacity 2.4.1 was released but it was decided that it was not serious enough to postpone the release, especially as 2.4.2 is scheduled to be a very short release cycle.
Ok thanks! Ill keep an eye out for the new release :smiley:
These are amazing! I’ve been playing with the settings, and really appreciate them for the whistles and clicks that get buried in some of my words. I’ll still Zoom In and Delete or Repair most of my noises, but for the ones that are difficult to find and isolate, these Effects work so well! Thank you!
There’s a couple of tricks to the DeEssing business.
Analyze > Plot Spectrum. Pick as high a Size as the system will allow. 16000 is good.
Low pitch tones on the left, high pitch tones on the right.
That blue haystack on the right is Essing.
Normal voices don’t do that. That’s the drilling teeth sound. The hump goes from roughly 4000Hz to 10000Hz, so those are the numbers I put in the DeEsser. Accuracy isn’t that important.
And poof. No more blue haystack and no more essing.
This works particularly well after you audiobook master because then the volume of the performance is fixed and you don’t have to go chasing after it with the DeEsser Threshold setting. Last I used it, I picked -30.
Hey … I’m excited to try this De-esser you’re all are talking about … but I can’t find it anywhere!
I have Audacity 2.3.2 and 2.4.2.
I’ve looked in all the drop downs.
I’ve been to the Installing Nyquist plug-ins page here:
And the ‘‘List of available plug-ins’’ here:
https://wiki.audacityteam.org/wiki/Download_Nyquist_Plug-ins#list
I can’t find ‘‘De-esser’’ anywhere.
What am I missing?
Thanks …
It is attached to the bottom of the first post of this thread …
Holy cow. I had to sign up just to say THANK YOU. You have saved me so much time with this. Once again THANK YOU SO MUCH.
The De-Esser doesn’t open directly from the link provided. What’s the name of the website,maybe I can downloaded from there. Thank you very much, Paul!!!
This is the website.
The download links are near the bottom of this post: Updated De-Clicker and new De-esser for speech
These are “Nyquist Plug-ins”. Instructions for installing Nyquist Plug-in on macOS: https://manual.audacityteam.org/man/installing_effect_generator_and_analyzer_plug_ins_on_mac_os_x.html#nyquist_install
[In Arnold Schwarzenegger voice]
Behold … the Desibilator, (attached).
This ‘desibilator’ plugin is Paul Licameli’s ‘DeEsser.NY’ just with different default-settings, different slider-ranges, & has tips added to the UI.
Previously the default frequency-range was not wide enough: it stopped at 8kHz, (now 13kHz).
Previously the “number of bands” slider went up to 1000 :open_mouth: , when <5 bands is generally sufficient, and >50 will freeze/crash Audcaity.
So this variant of Paul-L’s de-esser plugin is more likely to give first-time-users what they want, quickly, without crashing Audacity.
desibilator.ny (56 KB)
Install Waves Sibilance plugin in Audacity 2.4.2 Win10 & Mac
De-ess and de-click nyquist plug ins
How to remove harshness?
Help with fixing tinny/boxy/muddy audio talk
Getting my Voice in Videos for YouTube loud enough
de-esser
De-essing plug-in or directions for de-essing
How to reduce the bothering "s" & "ch" sounds??
My audio process for ACX
Reducing booming
Reducing booming
Opinion, please?
Opinion, please?
Noise reduction help
Spitfish de esser plug-in working good? but too good
Soft/light/calming voice effect
Как убрать резкие звуки с аудиозаписи
Attemping to initialize the following effect failed
How can I make my VoiceOver sound better
Help me fixing this audio file please
Multiple audio files at exactly the same volume.
A vicious circle with sibilants
Low frequency noise - is this normal?
best method to use noise reduction
Trying to install LISP de-esser on Windows 10
Recorded conversation adjustment.
Mind checking my voice test?
De-Ess Plug-In For Audacity
Too Hot? Fixable Distortion?
What is the best DeEsser?
First audio book and is this too echoey? or spitty?
I made such a rookie mistake. Can I salvage this?
#3 Volume post
Audacity 3.2.5 is out now!
Plugins not working after a reinstall (you wa shock and spitfish)
Z sounding sibilance
How to improve the sound.. Clattering and whistling peaks
Envelope tool vs Effect -> Amplify, vs Compression for interviews...
Audacity not recognizing AT2020
Metallic/Sharp voice on stereo but looks fine when using earphones
Asking for assistance from an expert
Tips to improve a VoIP call
Audio sample for review
Siblance plugin
How to remove phonograph-like crackle and hiss noises appearing after loud "S" and "F" vocals in audio?
Slight hum accompanying voice but not quiet sections
Clean up a tinny voice track
De-esser and De -clicker not working
.NY gems from the past
Audacity Plugins Not Showing in Effects
ACX, then noise floor, and pauses greater than 0.5 seconds
OUTPUT WAVE FILE MUCH LOUDER AND DISTORTED
Can You Over Do Sibilance cutting?
Audio Feedback request
New to recording - How do I prevent sss sounds?
sibilants
help fixing this audio quality
I'm not sure how to fix this hum issue. Despite the large amount of noise reduction I apply, there's still a lot of hum.
Narrator with NT1-A help equalise?
Starting Narrating Adventure and need HELP!!! Pleassssse
Same volume across files
trying to remove...sort of a purr? feedback or reverb?
please sample my narration
Which Mic is best suited for my Voice (Shure SM7B used so far)? With audio examples!
How to use the “Debu Labels (short)” or “Debug Labels (long)” feature?
Is there any label format that is assumed in that functionality?
Is there a way to generate those labels automatically?
Is there any user guide that explains details?
