Missing Clips, Corrupted Projects
Hi there,
I’ve recently started using Audacity to work on some projects where I do a lot of splitting / moving / copying of clips. I will frequently find that after saving and re-opening the project, clips will be missing. I can try re-copying them into place, but they are still missing after a save/reload.
It seems to be the same issue described in these two posts:
Audacity keeps corrupting my projects @sgiant
Audio clips disappear @Psiax
I don’t know how the files get into this state, but once they are, they just seem broken, unable to save any new edits. At no time do I get any error messages. Saving into a new project doesn’t help - it will also be broken in the same way. I’m using latest (3.7.4) but I saw it with the previous version too.
It’s getting quite frustrating. Any ideas?
Regards,
Ray
We all entrust software to reliably store the data (audio, etc.) that we give it.
So I decided to revert to v3.3.3 because my trust in more recent versions is gone. I was informed that it’s the last reliable version.
Will stay with that version unless or until there is a compelling reason to change. At that point, I’ll likely switch to different software.
Sorry for a rather depressing response. :confused:
Thanks for the tip. I wonder if I can have 2 versions installed at the same time? I like the STEM separation in 3.7 (not sure when it was introduced), but I suspect everything else I do is pretty straight forward, so the older version might but fine for that.
Obviously even better if the current releases didn’t have the issue!
You can totally do that on a Mac, however… Audacity keeps Settings, Mods, Adjustments, and Customizations in a separate place on the computer. This is so you can do a program update without having to reapply all your changes. I’d feel safe saying that the settings are different between 3.x.x and a 4.x.x.
I know one. 4.x.x will allow you to use the audio.com web-connected storage. In 3.x.x, you are strongly urged to do all your work on the local drive.
Are you doing all your work on the local drive? It’s a pretty terrible idea to do editing on external drives, the more external, the worse. Do Not do live editing on an internet drive.
Here’s longer thing I wrote about this.
It’s a link to another Audacity Post.
