Audio clips disappear
I opened a project to find that some clips disappeared.
  • Using v3.7.3
  • No error messages
  • The clips were all the same. That is, I created a clip of a few measures of drums, then made copies to create part of a track.
  • Other clips in the same drum track were OK and clips in other tracks are OK.
  • Happened once, recreated the missing clips, all was well until next day it happened again.
Any idea why this would happen?
Thank you!
Joe
I would offer to take a look but I don’t know how I’d be able to tell whether the clips were missing or not. Is there an easy way to tell?
Mark B
Hi Mark @evilmrb
Thanks for your reply.
I attached before/after screen shots.
I am able to recreate this easily…If I save the project, exit, then re-open the project the clips are gone.
Again, the missing clips are all the same (copied); the ones that remain are unique/distinct.
Any suggestions appreciated :slight_smile: as this is a killer bug
Joe
