She
November 16, 2023, 6:02pm
1
Hola, Como puedo importar o precargar todos los metadatos solo se importan los 7 predeterminados y se pierden los demás. Uso la versión 3.3.3 debido a que la 3.4.1 no puedo ni poner un metadato personalizado y ponerlo como predeterminando . Uso archivos lossless para convertirlas en flac y pierdo los metadatos en el proceso. Gracias por sus respuestas.
jademan
November 17, 2023, 1:32am
2
She:
Metadata is not imported
Hello, How can I import or preload all the metadata, only the 7 default ones are imported and the others are lost. I use version 3.3.3 because in 3.4.1 I can’t even put custom metadata and set it as default. I use lossless files to convert them to flac and lose the metadata in the process. Thank you for your answers.
Also, see these forum posts:
Hi there. Just downloaded 3.4. When I edit the metadata before exporting it no longer remembers the artist, album title, year, and genre from track to track - I have to type all the information in for each track. Previously it would automatically bring the information from the first track forward to the rest, and I would only have to edit the track name (if necessary).
Am I missing something?
K.T.
Hello:
Why did the MetaData change and is also now broken?
Before I would use Alt+3 mapped as a shortcut key to export as MP3.
Then after entering the FieName, it would bring up the Metadata window.
I would enter the Metadata for the first file, Save it, and then Set as Default.
Then, for the second and succeeding files, I would just have to change the name and the Track number.
BUT NOW, I have to make an extra Click to EDIT MetaData.
Then I enter, Save, and Set as Default.
BUT on the ne…
Having problems exporting multiple files from 3.4.1. Using it to grab a whole LP and then export each track as a FLAC file. Previous version correctly allocated Album and Artist metadata to each file as its exported, (and asked for confirmation on each track), but 3.4.1 only puts that metadata on the first exported file. Also, the behaviour has changed, in that “Export Multiple” no longer appears as a specific option, only a switch on the Export window. This means that every file has to be post…
