At the moment, we don’t know. We don’t even know yet if Apple’s new “notarization” requirements are compatible with Audacity’s GPL license. The Audacity developers will be working on a version for Catalina, if it’s legal to do so.
I just got Catalina on my mac and have been trying to use it with audacity 2.3.2 and it will not record sound. When I check my privacy and security the audacity app doesn’t show up in the microphone tab. I followed the instructions on how to download, download the dmg for 2.3.2 then drag the audacity icon to the app folder, so I am not sure what is going on.
Audacity appears to work on Catalina for some users, but it is not yet officially supported.
This is not related to 32/64 bit applications, but rather to additional unannounced changes that Apple have made.
The issues on Catalina are NOT driver related, but related to some of the new security and permissions requirements in Catalina.
First, when an application attempts to access any sound input device, said application requires explicit permission from the user before it can access the mic. Second, there are additional protected folders in Catalina that applications also need to explicitly ask permission to access (such as Desktop and Downloads). For some reason, Audacity does not ask for these permissions, and as such can’t access the necessary resources to work.
However, there is a work around!
You can open Audacity via the terminal using the following command: open /Applications/Audacity.app/Contents/MacOS/Audacity
This will open Audacity and then Terminal will actually ask for the correct permissions. If for some reason this doesn’t work, you can try opening Audacity as root: sudo open /Applications/Audacity.app/Contents/MacOS/Audacity
Finally, this assume that Audacity is stored in your Applications folder. If it’s somewhere else, you’ll need to change the path in the above command: open /location of audacity/Audacity.app/Contents/MacOS/Audacity
For example: open /Applications/Utilities/Audacity.app/Contents/MacOS/Audacity
Hopefully these issues can be solved in short order (I haven’t run into anything similar with other apps).
So making a desktop alias of the Audacity executable requires you to open up the contents of the Audacity.app package. To do so:
• Right click (or two finger click, depending on how you have your mouse/trackpad setup) on Audacity.app (which, in the Finder, is essentially the app itself).
• In the right-click menu, select “Show Package Contents.” This will open a new window with the contents of the Audacity.app package, and it looks just like any other folder.
• in the package contents folder, navigate to the “Contents” folder, and then the “MacOS” folder.• In the MacOS folder, there is an item simply labeled “Audacity” with NO file extension. This is the Audacity Unix executable.
• Drag this file to the desktop while holding down the “Control” key. This will make a shortcut of the executable that can be simply double clicked on.
• When the exe is opened, Terminal will open first, and the Audacity will open.
There is one big caveat to using the above method: In order to open up an Audacity project, it must be opened from within Audacity AFTER you open Audacity following the above methods. If you just double click on an Audacity project, it will open Audacity as normal, and things just won’t work properly.
Not sure if this is allowed in the forums or not, but I created a really simply “Automator” script that you can simply double-click on to open Audacity and have it working. Because Automator allows you to save these scripts as an application, you can actually pin the script to the Dock just like any other program.
I’d be more than happy to throw it up on a file sharing site and post the link here, but like I said, not sure if sharing files like that is allowed here or not.
