Error message when importing mp3-file
Re: Error message when importing mp3-file
Post by steve » Mon Apr 19, 2021 3:24 pm
юра00 wrote:
Mon Apr 19, 2021 2:48 pm
I tried another program, wxmp3val 4.0. It seems to be working. Thank you!
Super. Thanks for the update.
юра00
Post by юра00 » Thu May 13, 2021 12:32 pm
What's this with the import again? The program doesn't help. The file is easily played. Audacity version 3.0.2 (release)
https://mega.dp.ua/ru/L4sw
Post by steve » Thu May 13, 2021 2:14 pm
If you have "FFmpeg for Audacity" installed, try selecting "FFmpeg compatible files" in the Import filter.
(see: https://manual.audacityteam.org/man/imp ... audio.html)
юра00
Post by юра00 » Thu May 13, 2021 4:46 pm
Thank you, it worked. Though, I don't wish to install this component. So, can't do without it?
Nimitta
Post by Nimitta » Sun May 30, 2021 4:00 pm
FFmpeg didn't help. Still the same issue.
Post by steve » Sun May 30, 2021 4:11 pm
Does the file play in other apps?
What does this site say about the file? https://mediaarea.net/MediaInfoOnline
юра00
Post by юра00 » Sun May 30, 2021 4:53 pm
You should move the line on the top of the list. (Edit - Preferences - Extended import) Otherwise, it won't work.
