Would it be possible to add a hot key for the Stop action?
Hi,
Is it possible to add a micro/hot key for the Stop action? I searched Edit → Preferences → Keyboard, but don’t see Stop in the list.
It would be helpful/easier if we could use hot key to Stop playing a track.
Thanks & regards,
Lee
To stop playback or recording, press “Space”.
The “p” key will pause either recording or playback.
Wow, I miss this one. Thank you. Is there a place where we can find these useful definitions?
Regards,
Lee
Have a look at: Commands and Keyboard Shortcut Reference - Audacity Manual
Note carefully that there are two sets of shortcuts:
a) the default standard set,
b) the full set.
The full set contains all the ones that are in the standard set but adds a lot more.
One other useful one you may like is “X(as in “X marks the spot”) - this stops Play (or Record) and sets the cursor to the current play/record position - more useful for Play than Record.
Peter.
Thank you for the information. Those shutcuts are very helpful and save time.
Regards,
Lee
