Mac OS 10.12.5
Audicity version 2.1.3
Obtained .dmg installer
Hello Everybody:
I’m hoping to learn how to correct this audio, which has quite varying volume levels, as well as other issues.
It is a video/audio recording of a panel discussion with audience questions. One hour in length.
I’ve exported the audio from iMovie, importing the one mono audio track into Audacity
Some of the audio is fine as far as volume is concerned: right around -12dB
Other parts: too loud, sometimes up to 0dB or more, including some clipping.
And: still other parts, the person’s voice is too soft to be understood.
There is a fair amount of room noise, as the room has hard walls - a pretty live room.
My main concern is: which audio effects to use, and in which order, to get the volume at a reasonable level.
I’m pretty sure that if I can make things sound more uniform, I can work with the noise reduction effect.
I would appreciate any help that other may offer.
Thanks
George
