Using a macro jums up to middle of project
Im on Windows 11 using audacity 3.5.1
I have a macro that uses the limiter then normalises, when I use it on a piece of voice audio I’ve recorded (which is always at the bottom of the project) my view jumps up to the top of the project. So I have to scroll down to see what the result are, or to continue working on it , or move it to the right place in the project. I make a radio show with up to 20 audio tracks and 10 vocal tracks so this is really annoying not to say time wasting
any ideas on how to stop this happening
I must say 3.5.1 is pretty good and enjoy using it now Ive got used to it but I really dont like the way the arrow buttons on the side and bottom scroll bars (uo and down and side to side scroll) disappear when the curser isnt in/on the scroll bar there seems to be no reason except for fashion for this and I guess it takes up more code and resources iykwim
please put the solid arrow buttons back
thanks
It isn’t like that for me on W10 with 3.5.1 latest release or the Beta test build for the upcoming 3.6.0 release.
For me the scroll bar arrows are always present, regardless of the cursor position.
Peter.
thanks for that Peter
I found that if I move the track I’m working on up from being the bottom track when applying the macro, the view does not jump to another part of the project
Maybe we’re taking about different features I mean the bar and arrows I just got 3.6.1 installed and its the same you have to hover over a thin line to make the scroll bar visible and usable.
I’m on windoze 11 and have ‘always show scrollbars’ on in the windoze settings
