If I make an edit, and then save and close the project, and then open the project again, can I undo that edit that I made in the previous session?
If I stay in one session, make an edit, then save the project–can I still undo the edit after I save the project?
Let’s say I stay in 1 session and I make 3 edits in this order: edit1, edit2, and edit3. Then I want to undo edit2 without undoing edit3–is this possible? Or would I have to undo edit3 and then undo edit2?
Hi Peter,
Thank you for your very clear answers, which were what I expected, except for the 2nd question.
It seems that the only way I can preserve the ability to “roll back” to a previous version is to save the project with “Save As” and store each version under a different name.
Thanks, Chaim
Yeah, you’re discovering here why we’ve been pushing non-destructive editing so hard since 3.1.
3.1: Non-destructive edits
3.2: Non-destructive effects
3.4: Non-destructive clip stretching
3.5: Non-destructive pitch shifting
And of course, things like the envelope tool and the pan sliders are non-destructive as well. So the more recent your Audacity version is, the more likely it is that you can undo an edit you made in a previous session.
