Win 7.
Realtek HD Audio
Audacity 2.0.2
Is there any way of recording audio coming from a web site? I’ve followed various earlier posts and advice but end up with silence being recorded.
I’ve set MME and Stereo Mix
Win 7.
Realtek HD Audio
Audacity 2.0.2
Yes, your best bet is to use WASAPI loopback in the Device Toolbar.
See this Tutorial in the Audacity Manual: http://manual.audacityteam.org/o/man/tutorial_recording_audio_playing_on_the_computer.html
Thanks. I’ve seen and thought I had followed that tutorial already, without success. I understand the tutorial to say that WASAPI loopback is used for recording when a USB device is used. I am using a sound card.
I don’t see WASAPI in any case.
You need to follow the link on that page to the Windows specific instructions: http://manual.audacityteam.org/o/man/tutorial_recording_computer_playback_on_windows.html
See also the Device Toolbar page: http://manual.audacityteam.org/o/man/device_toolbar.html
Or do you mean that you don’t see WASAPI available in the host dropdown in your Device Toolbar?
It should work fine, I do this two or three times a week on a W7 laptop with a Realtek card.
WASAPI host requires 2.0.4 or later. I suggest you update to the current 2.0.6 from Audacity ® | Download for Windows.
I love using Audacity to record streams off of the internet. I used it for years on Windows XP & may have had to play around with it a bit, but it was well worth it.
When I got a new laptop, however, I had issues trying to get it to work again. I think Microsoft changed things around a bit, I think some felt they were deliberately trying to make it difficult/impossible to record streams directly. But I did eventually get it to work with Windows 8.0 & after the 8.1 update.
I don’t know if your issues are related to the ones I had to overcome, perhaps not, as I couldn’t get the “stereo mix” option to show on the drop down list. Once that showed up, I was good to go.
Here’s a link to page two of the thread here where I was trying to figure it out: Missing stereo mix in Windows Pro 64bit - Windows - Audacity Forum
Here’s a link to the post where I described what I did to get that stereo mix option to show up in Windows 8:
Here’s a link to a post by kozikowski about a Behringer UCA 202 which I eventually did purchase so that I could also record from a stereo system. It may be an option for that loop that they’re talking about, where you plug your audio out into the Behringer & then back into your computer via a USB port:
Hopefully I’m not confusing things more than helping. I’m just a novice myself, but maybe there’s something in all of that that might be helpful.
Thanks all, especially Gale.
Windows WASAPI is mentioned in the tutorial that was quoted, but the crucial information I supplied seems to be that I was using 2.0.2. I think Waxycylinder missed this. I cannot see in the tutorial that WASAPI is not part of 2.0.2
The solution I stumbled across was to download 2.0.5. Thereafter the tutorial works because WASAPI then appeared.
I’m now working. Thanks again.
How it works is that if you get the EXE installer for your version of Audacity, you will have a “Help” folder containing the Manual specific to that version of Audacity. You can access that installed Manual from Help > Manual in that version of Audacity.
If you go to the online Manual Audacity Manual that is only the Manual for the current version of Audacity, so 2.0.6 at the moment. It’s not generally practical to make a Manual that includes details for previous Audacity versions.
