Tutorial mistake
In the “Recording audio” tutorial, this instruction is given:
  1. Test your Settings
    Select the microphone icon and choose Start Monitoring
But selecting the microphone icon does not bring up “Start Monitoring” in the dropdown window; only “Enable Silent Monitoring” and “Other Options” (which does not include “Start Monitoring”).
I’m at a standstill until I can resolve this problem, hope you can help.
@DaveAllikas Is this in the manual or on the Muse Support site?
Can you provide a link to the tutorial please?
Peter.
Manual. Below is the link. Thank you Peter.
Recording your voice with a microphone | Audacity Support
@DaveAllikas
Thanks for the link Dave,
that is actually the Muse support site and not the Manual.
I’ll log an issue on the Muse issue tracker for their Support site.
If it was the manual I could have fixed that - but I don’t edit the Muse Support site. But I will check that any such material in the manual is correct for the upcoming 3.7.2 release.
Peter.
Logged as:
Thank you Peter.
