I am trying to create some custom presets but Audacity keeps shutting down on me. I have created a preset name, hit insert, go to Filter Curve EQ and then Audacity shuts down when I try to edit parameters. I have tried multiple times. I do have Audacity 3.2.1.
Anyone have thoughts or ideas?
You’re not the only one having problems with the macro manager in 3.2.1.,
see … https://forum.audacityteam.org/t/editing-commands-in-macro-manager/65807/3
Do you care to post a screenshot ?
Same thing keeps happening to me when I go to edit the filter curve in Macro Manager. Come on, Audacity, fix please?
This appears to have been fixed for the upcoming 3.2.2 maintenance release - which should hopefully be out later this month.
I tested on W10 with the latest Beta test build I have for 3.2.2 and it works fine.
Peter
