I know this might sound strange but, I wonder if there’s a way for me to make a noise generator that generates the common siren tones, wail, yelp, phaser/piercer (hyperyelp), Horn, and hi-lo? If there is, what would be the code for me to make these? Also, being blind, how would I make this into a plugin? The horn example I’m thinking of can be found on this video: https://www.youtube.com/watch?v=Ul127xTb5K0
I think this is a reasonably good approximation of the “Track 68” siren without making it overly complicated (below).
Perhaps you would like to have a go at the others yourself. Give a shout if you get stuck.
;type generate
(setf duration 10.0) ; duration in seconds
;Make a skewed triangle waveform
(defun mod-table ()
(let* ((mod-table (pwlv -1 0.55 1 1 -1)))
(list mod-table (hz-to-step 1.0) t)))
(setf *table*
(sum (mult 0.5 (build-harmonic 1.0 2048))
(mult 0.05 (build-harmonic 2.0 2048))
(mult 0.05 (build-harmonic 3.0 2048))
(mult 0.03 (build-harmonic 4.0 2048))
(mult 0.02 (build-harmonic 5.0 2048))
(mult 0.01 (build-harmonic 6.0 2048))))
(setf *table* (list *table* (hz-to-step 1.0) t))
(setf siren
(let ((mod (hp (osc (hz-to-step 0.22) duration (mod-table)) 0.3))
(env (sum 1.4 (hp (osc (hz-to-step 0.22) duration (mod-table))0.3))))
(setf mod (sum 480 (mult 530 (sum 1 mod))))
(mult 0.5 env (fmosc 0 mod *table*))))
(mult 0.3 (jcrev siren 2.0 0.3)) ; add a bit of reverb
And you can make this with any waveform? I remember trying something similar with a square wave, but for some reason, I heard this wavy wiggly sound when it would rise and fall. I could be wrong, but I think that’s aliasing. Is that some kind of change in sound quality?
In the code (my last post), you will see that I have used “build-harmonic” (http://www.cs.cmu.edu/~rbd/doc/nyquist/part8.html#index344) to create a wave-table with 6 harmonics. I did this to ensure that the frequency content of the waveform would not exceed the “Nyquist frequency” (digital audio cannot produce frequencies above half the sample rate, which is known as the “Nyquist frequency”). Using a simple triangle, saw or square wave for the tone will, as you say, cause “aliasing distortion”, which can be very noticeable with a sweeping tone. By generating the waveform with a restricted number of harmonics (in this case, 6), aliasing distortion can be avoided.
I tried putting that code in Nyquist Prompt, and I got the following error:
error: illegal character - -62
Function: #<Subr-(null): #a7e16b0>
Arguments:
#<File-Stream: #36b2180>
1> error: illegal character - -96
Arguments:
2> error: illegal character - -62
Arguments:
#<File-Stream: #36b2100>
Arguments:
3> error: illegal character - -96
Arguments:
Arguments:
4> error: illegal character - -62
Arguments:
Arguments:
5> error: illegal character - -96
Arguments:
Arguments:
6> error: unbound variable - MOD-TABLE
if continued: try evaluating symbol again
Arguments:
Arguments:
7> error: misplaced right paren
Function: #<Subr-(null): #a7e1690>
Arguments:
Arguments:
Arguments:
8> error: misplaced right paren
Arguments:
Arguments:
Arguments:
Arguments:
9> error: illegal character - -62
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
10> error: illegal character - -96
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
11> error: illegal character - -62
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
12> error: illegal character - -96
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
13> error: illegal character - -62
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
14> error: illegal character - -96
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
15> error: illegal character - -62
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
16> error: illegal character - -96
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
17> error: illegal character - -62
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
18> error: illegal character - -96
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
19> #<Sound: #44f0568>
19> error: illegal character - -62
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
20> error: illegal character - -96
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
21> error: illegal character - -62
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
22> error: illegal character - -96
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
23> error: illegal character - -62
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
24> error: illegal character - -96
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
25> error: illegal character - -62
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
26> error: illegal character - -96
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
27> #<Sound: #44f0670>
27> error: illegal character - -62
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
28> error: illegal character - -96
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
29> error: illegal character - -62
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
30> error: illegal character - -96
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
31> error: illegal character - -62
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
32> error: illegal character - -96
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
33> error: illegal character - -62
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
34> error: illegal character - -96
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
35> #<Sound: #44f0768>
35> error: illegal character - -62
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
36> error: illegal character - -96
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
37> error: illegal character - -62
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
38> error: illegal character - -96
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
39> error: illegal character - -62
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
40> error: illegal character - -96
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
41> error: illegal character - -62
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
42> error: illegal character - -96
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
43> #<Sound: #44f0860>
43> error: illegal character - -62
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
44> error: illegal character - -96
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
45> error: illegal character - -62
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
46> error: illegal character - -96
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
47> error: illegal character - -62
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
48> error: illegal character - -96
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
49> error: illegal character - -62
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
50> error: illegal character - -96
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
51> #<Sound: #44f09f0>
51> error: misplaced right paren
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
52> error: misplaced right paren
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
53> ((#<Sound: #44f0078> -36.3763 T) -36.3763 T)
53> error: illegal character - -62
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
54> error: illegal character - -96
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
55> error: illegal character - -62
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
56> error: illegal character - -96
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
57> error: illegal character - -62
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
58> error: illegal character - -96
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
59> error: illegal character - -62
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
60> error: illegal character - -96
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
61> error: illegal character - -62
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
62> error: illegal character - -96
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
63> error: unbound function - MOD-TABLE
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
64> error: misplaced right paren
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
65> error: illegal character - -62
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
66> error: illegal character - -96
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
67> error: illegal character - -62
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
68> error: illegal character - -96
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
69> error: unbound variable - MOD
Function: #<FSubr-SETF: #a7dbf20>
Arguments:
MOD
(SUM 480 (MULT 530 (SUM 1 MOD)))
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
70> error: illegal character - -62
Arguments:
MOD
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
71> error: illegal character - -96
Arguments:
MOD
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
72> error: illegal character - -62
Arguments:
MOD
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
73> error: illegal character - -96
Arguments:
MOD
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
74> error: unbound variable - ENV
Arguments:
MOD
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
75> error: misplaced right paren
Arguments:
Arguments:
MOD
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
76> error: misplaced right paren
Arguments:
Arguments:
Arguments:
MOD
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
77> error: unbound variable - SIREN
Arguments:
Arguments:
Arguments:
MOD
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
78> 77> 76> 75> 74> 73> 72> 71> 70> 69> 68> 67> 66> 65> 64> 63> 62> 61> 60> 59> 58> 57> 56> 55> 54> 53> 52> 51> 50> 49> 48> 47> 46> 45> 44> 43> 42> 41> 40> 39> 38> 37> 36> 35> 34> 33> 32> 31> 30> 29> 28> 27> 26> 25> 24> 23> 22> 21> 20> 19> 18> 17> 16> 15> 14> 13> 12> 11> 10> 9> 8> 7> 6> 5> 4> 3> 2> 1>
Check that you have copied the code correctly. If you still get the problem, please post exactly the code that you are using in the Nyquist Prompt.
The code I copied into the Nyquist Prompt is exactly the code you posted on the forum, at least as far as I know. Here’s what I copied.
;type generate
(defun mod-table ()
(setf table
(setf table (list table (hz-to-step 1.0) t))
(setf siren
(mult 0.5 env (fmosc 0 mod table))))
That looks OK.
Which version of Audacity are you using?
Are you applying the code to an empty mono track?
- I use Audacity 2.1.0
- I’m applying the code to a track with audio, since the Nyquist Prompt won’t let me apply to an empty track.
- The track is a stereo track.
The duration will not be correct in Audacity 2.1.0 because that version does not support the “;type generate” instruction. You need Audacity 2.1.1 for it to work correctly.
Regardless of that, I am not able to reproduce that error using Audacity 2.1.0, so I don’t know what the problem is. -
To use the Nyquist Prompt effect, you do not need to select “audio”, but you do need a “selection” in an audio track. You can create a selection in an empty track by creating a new track (Tracks menu), then move focus to the Selection Toolbar, then tab across to the second time box and enter an “end” or “length” time.
I intended the code to run on a mono track, but it does also work on stereo tracks.
As you are interested in working with Nyquist code I’d recommend keeping up to date with current Audacity versions (currently 2.1.1) because there have been some useful updates recently, and are likely to be additional useful features coming soon.
I’ve now tried it in Audacity 2.1.1, with an empty track and selecting a length, and I get this error.
Function: #<Subr-(null): #380c1c8>
Arguments:
#<File-Stream: #3682ab8>
Arguments:
Arguments:
#<File-Stream: #3682a38>
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Function: #<Subr-(null): #380c1a8>
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
19> #<Sound: #44508a0>
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
27> #<Sound: #4450900>
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
35> #<Sound: #4450520>
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
43> #<Sound: #4450618>
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
51> #<Sound: #44507a8>
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
53> ((#<Sound: #4450078> -36.3763 T) -36.3763 T)
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Function: #<FSubr-SETF: #38069e8>
Arguments:
MOD
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
MOD
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
MOD
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
MOD
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
MOD
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
MOD
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
MOD
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
MOD
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
MOD
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
Arguments:
How exactly are you entering the text into the Nyquist Prompt? Please describe exactly so that I can do it in exactly the same way.
Basically I’m copying and pasting the code from a text file. Is that not what I’m supposed to do?
How are you creating that text file?
I think that the web browser is the problem.
Unfortunately, Mozilla Firefox renders some characters in the wrong way, e.g. space has not Character number 32 but 160 instead.
Copying works fine with Internet Explorer.
Which Browser and Screen reader do you use, Annabelle?
Robert
When we get this copy/paste issue sorted out you can try this better approximation of the slow siren:
;type generate
(setf low-hz 700)
(setf hi-hz 1220)
(setf level 0.4)
(setf reverb 0.03) ;amount of reverb, 0 to 1
(setf hz-range (- hi-hz low-hz))
(defun env-table ()
(let* ((env-table (pwlv -1 0.55 1 1 -1)))
(list env-table (hz-to-step 1.0) t)))
(setf *mod-table*
(seq (mult -1 (sum -1.002 (pwev 1.002 0.527 0.002)))
(pwlv 1 0.473 0)))
(setf *mod-table* (list *mod-table* (hz-to-step 1.0) t))
(setf *table*
(mult 0.025 (build-harmonic 2.0 2048))
(mult 0.025 (build-harmonic 3.0 2048))
(mult 0.005 (build-harmonic 4.0 2048))
(mult 0.002 (build-harmonic 5.0 2048))
(mult 0.0003 (build-harmonic 6.0 2048))))
(setf siren
(let ((mod (osc (hz-to-step 0.21) duration *mod-table*))
(env (sum 1.4 (hp (osc (hz-to-step 0.22) duration (env-table))0.3))))
(setf mod (sum low-hz (mult hz-range mod)))
(mult level (jcrev siren 2.0 reverb)) ; add a bit of reverb
I use JAWS 10.0.1178U with the latest version of Mozilla Firefox.
- I navigate to the link that says “Select All” above the posted Nyquist code, then press enter.
- Or I simply manually select the lines of the code, then press Control+C to copy it to the clipboard.
- I paste it into a text file in Notepad.
- I go into Audacity.
- Make a new track, either Mono or Stereo.
- Select the length of time using the Selection toolbar.
- Press Alt+c to enter the Effect menu, then N until it says “Nyquist Prompt”.
- Paste the Nyquist code from the clipboard, all lines including blank lines.
- Press OK, and that’s when the error appears.
So, it is the browser, as I said - I use NVDA and the same happens.
Normally, one should be able to change the text encoding.
However, this does not seem to work in Firefox (View Menu → Text Encoding).
There’s also a JAWS command to copy pure text, perhaps this will automatically change the Characters to ASCII.
Robert
I’m trying to follow the steps using NVDA.
I can tab down to the “Select All” link, and pressing “Enter” then selects the code, but focus is still on the link. If I then press Ctrl+C to copy, NVDA tells me “No selection”. How do I copy the selected code?
When NVDA is not running, I can tab to the “Select All” link, press Enter, and then Ctrl+C to copy.
Do I need to change something in NVDA for that to work when NVDA is running?
