The delay in the ability to copy multiple music tracks from one project and paste to a new project
Copy and Paste - Not responding .. Ihave a 14 track music recording of several songs. I wish to copy one song with all 14 tracks and open a new project to enable me to mix/master the song. The song I copied is 5 minutes long and it takes a very long time generate the new project after a paste and slways reads “not responding” in the header. It finally renders after a minute or two of spinning
To be clear, you have a project with 14 tracks and several songs one after another on those tracks? You make a selection across the 14 tracks, Copy, then Paste into a new project.
If this is the case, what is happening is Audacity is actually bringing all the audio on all 14 tracks into the new project, but just displaying the sections you selected when you copied the audio.
This is because of “smart clips”.
I’ve raised an issue on Github to have this addressed.
There is no way around this in Audacity 4.
If you want to get around both the delay and the presence of the audio of all the other songs in the second project, you’ll need to migrate your project to Audacity 3. If you want to do that let me know.
See this post for a similar report:
