I need to know how to create a track for the signal and a track for a synchronization. For example one track is a sinus 1kHz and another track is a square signal 1 Kkz too (this signal is use as a synchronization). I have material that I would like to check their synchronization. Thanks for your helps.
Thank you for your link. I can now create a sinus and square but I have a problem. I need to have a Sinus in the left and Square in the right to get a stereo signal. See in this attached after export to wave file I have only one way the square signal. Do you how can I do that ? Thanks
Sorry I can find the necessary informations. At this step (I have 2 mono channel : Sinus and Square) and How Can I do to make a wave file stereo with this step ? Thanks
To combine mono tracks into a stereo track, the tracks must be directly one above the other.
The order of tracks in a project may be changed by either:
Click on an empty part of the panel on the left end of the track (where it says “Mono 44100”), taking care to not click on the sliders, and drag the track up/down.
I don’t need to change or drag up/down the order of the tracks. I just need to make a stereo signal with on the left (Sinus) and the right (Square). Can you see this file please ? At the end I can only a mono file. And I need the stereo file where the left is sinus and the right is square or vice versa.
Hi,
After I repeat the first way I have 2 Channels stereo
But when I export this file I have only one channel stereo Why ? I need 2 Channels and not 1 Channel, do you know how to create ? Thanks
As this is an English language forum, please don’t just post screenshots of messages. Please type the message as text, preferably in English, but if you’re unsure of the translation, type it in French and we can look it up with Google Translate. We cannot use Google Translate with a screenshot.
Sorry for the screen shot in french. I need to know if it’s possible to make a file (.wave) with 3 channels on the same file. As I can create before one channel (Right (sine)+left(square)), why when I export 2 channels I’ve only one channel with this message warning “….that all tracks in the project will be mixed down to a single stereo file”. After reading your last message I don’t know Why must I create a new projet for each stereo file ? Thanks for your helps.
Yes it is. You need to enable “Advanced Mixing Options” in Preferences.
“Edit menu > Preferences > Import / Export > Use Advanced Mixing Options: ”
See: Advanced Mixing Options - Audacity Manual
Yes thanks, I’ll read after but one question before to try making this file. Do you know if there is no shift (lag) between the channel 1 and the Channel 2 etc… I need a file that the start time is the same for thèses three channels. It’s very important for our analysis. For example see below :
I arrive to create 3 channels with 6 tracks. I have a picture (sorry but the picture is in french) :
I think (Piste audio - G and Piste audio - D) (audio track - G and audio track -D) is for the channel one. And after is for channel 2 and channel 3 I suppose. But for the moment I have a file to play with the 5.1 audio system and after analysis I’ll see later. Thanks you for your helps Steve
