Sync
Hi,
I have to synchronize two tracks for a Muxing (audio/video) and I want to raise the peaks of one of them to better see the differences, this can be done with the ‘compression’ filter but I would not want to ruin the track, there is a way after working the track to cancel the ’ compression 'and make the file cone to the origin?
Thanks
  1. apply the compression
  2. listen to the result
  3. If you are unhappy with the result use Edit > Undo or its shortcut Ctrl + Z
It’s also worth making a backup copy of your project in a good known state that you cna revert to. For this use File > Save Peoject > Backup Project - giving the backup a (slightly) different name.
Always a good idea. Export a protection WAV copy of your raw reading or performance before you mess with it.
Yes, but.
Say you increased the sound peaks to see what you’re doing, and then Time Shifted the performance to be spot on. UNDO will remove the time shift.
I might apply Effect > Amplify a known, fixed amount rather than one of the compression tools, do the time correction now that I could see what I’m doing, and then Effect > Amplify again the opposite amount to remove the initial boost. Amplify is a simple sound volume change and is reversible with no damage inside Audacity.
I can’t use Ctrl + Z because after compressing I have to edit the audio with cut and paste and I can’t delete them
When I need to do something like this, I use Ctrl-D to duplicate the track. I MUTE the original track and work with the copy. This way, I can always refer back or even revert back to the original track.
Let me explain better :slight_smile:
I have to put the two tracks side by side to compare the audio peaks then I have to cut and copy parts of that compressed one and save it, even if I make a copy I don’t solve why I have to save the worked one
