I have been using Pro Tools and I want to switch to Audacity. My system is Windows XP. I have a MXL 909 mic and Mbox 2mini. I have worked with 7.1 Pro Tools. I am a Voice Over Artist and do a Podcast…What do I need to change ??? I am not an engineer and any help would be appreciated.
Thanks,
jimmytheg
Do you use any post-production processing in Pro Tools? Unless the tools are plain like change loudness, they’re likely to be very different between the two programs. I think they will both do a good job with simple recording.
For one significant example, I don’t know if Pro Tools will apply tools and filters during recording, but Audacity will not do that.
Audacity does have a tool you might like. Flynwill developed “ACX Check,” which will tell you if your recording will likely pass the ACX AudioBook Quality Control robot on submission.
I notice you asked the same question a year ago. How far did you got with this response Using a m-box with audacity - #6 by Gale_Andrews ?
