I have a question
I have a large audio file ~650 minutes playtime
I want to swap the output between right and left ear.
5 seconds on the left ear, the next 5 seconds on the right ear, the next 5 seconds again on the left ear and so on…
With ~650 minutes playtime I cant do that manual…
Is there a solution ?
How I can do this ?
Would be very nice if someone can help me.
I can’t think of a good way to do this automatically, but as a first step I would not actually swap the channels. I would create two stereo shows one above the other. The bottom show is backwards left to right. Then all you need to do is switch between them at five second intervals. Much easier than trying to manage a single performance.
But I don’t know how to automate the switching, so we’re no further ahead.
Audacity has Chains which is the batch or automation tool.
There is a plugin which will do that … panlfo2a.ny
First you’ll have to create a dual-mono version of your track …
duplicate the track (“Ctrl” +“D”), then marry it to the original via “make stereo-pair”.
Then apply panlfo2a.ny … I think processing 650 minutes in one go is too much,maybe process it in hour-long chunks.
I found this thread in order to figure out how to create a dual mono, making my left channel appear in both channels. I have current Audacity (2.2.2), yet there is NO “split stereo track” option in the tracks dropdown. (Was going to start a new thread, but maybe this thread can help.) I cannot figure out how to even select one track (left or right) of the two there.
