Suggestion for Ripping (?) old LPs
I am running IMAC OSX 10.9. Downloaded Audacity 2.0.5. Downloaded LAME and had the same issues of finding it until I was able to get it into the Audacity folder in my Applications. Everything actually seems to be properly working!!!
NOW my question. I have a “lot” of old LPs to digitize using my new Crosley USB turntable. I want to put them into ITUNES. Should I copy one song at a time off of each LP or do I copy the entire LP into one file?
Where is this discussed? In the manual, online, or not at all? What do you suggest?
Thanks, all.
Hooray :smiley:
You’re in luck. Several of the documentation team have done lots of vinyl to digital transfers, so there is a lot of documentation on the subject.
If you already have the basics of recording with Audacity, then this work-flow (from the manual) will probably be the most useful: Audacity Manual
And this workflow for getting stuff into iTunes: http://manual.audacityteam.org/o/man/sample_workflow_for_exporting_to_itunes.html
This full set of tutorials may be useful to you too: http://manual.audacityteam.org/o/man/tutorial_copying_tapes_lps_or_minidiscs_to_cd.html
I, personally, normally work with one side of an LP at a time as it gives me a smaller working set - capture, edit, export the WAV files - then side-2. I also use Brian Davies’ excellent ClickRepair to remove the clicks and pops = this package costs a little (c. US40) but is little shy of magical in the results it can achieve, it saves me a lot of time too. See this sticky thread: https://forum.audacityteam.org/t/click-pop-removal-clickrepair-software/1933/1
