I have read the section on the online help files on Preferences but I am having trouble storing/saving these.
I am using Audacity to look at Bat data. So very short HF files usually a couple of MB, lasting a couple of seconds. I have thousands of files to look through to determine if there are bat calls in each file. Each time I open up a WAV file in Audacity I have to change the preferences to be able to view the spectrogram in the right way to determine if there is any bat data. How do I save the configuration so I do not need to change this every time I open up a new file? I apply the settings and then click ok.
When I do a search it is telling me this file is in:
C:\Users\Kenny\AppData\Roaming\Audacity
When I go into the Kenny folder, I cannot even see the AppData folder
When I go to open this folder from the search folder it tries to download the installation wizard for Audacity.
But even so, the configuration may save, but it is not applied to how I open up a file the next time. So have to set everything all over again for to view every single file. Is there anyway round this? Thank you.
