I am using Windows 10 Pro.
I have recently downloaded and installed : SSL Native Software X-Echo and Native X-EQ 2
According to the Audacity manual - Audacity does support Steinberg VST plug-ins.
“All the directories where you can place VST plug-ins are searched recursively, which means that plug-ins that are inside their own folder in that directory should still be found by Audacity.}”
According to iLok. Both SSL plug-ins are registered and active on my computer.
Here is the path on my computer’s drive that they reside:
C:\Program Files\Steinberg\Vstplugins ,but do not appear in the “manage plug-ins” window of Audacity
The question here is - why doesn’t Audacity recognize and open the two Plug-in files?
