Splitting the sides of a stereo track
Hi.
I exported a mono track but inadvertently had it panned 70% to the left. Then I closed the program and didn’t save the original file.
When I opened the new track it had been made into a stereo track with the audio on the top identical to, but quieter, than the audio on the bottom. Is there a way to get it back to just a mono track at the original volume? Or is there a way to “split” the left and right of the stereo track so I can just delete the side that is quieter?
Thanks. Hope this makes sense.
70% left should give you the left (top) channel at the original volume and the right (lower) channel at lower volume.
So use the Track Drop-Down Menu to Split Stereo Track, then use the top left of the quieter track to close it.
Not seeing ‘Split Stereo Track’ in any of the drop down menus.
I am using version 2.0.3
Is it hidden somewhere I can’t find?
Thanks.
Mark
Its in the Track Control Panel dropdown menu - see: http://manual.audacityteam.org/o/man/audio_tracks.html#panel
and: http://manual.audacityteam.org/o/man/track_drop_down_menu.html
