I’m a bit of a newbie. The track in the image shows as staring at 4:49mins. I want to have it start at zero, and can’t figure out how to do it. Any advice gratefully received. Thanks!
Select from 4:49 back to zero and then press Delete (if you keyboard has one) - or used Edit > Delete or it’s shortcut Ctrl + K
There are other ways but this is probably the simplest.
Peter.
Many thanks, Peter. Successfully done. Appreciate your wisdom and experience.
