Saving Stored Cursor Position When File Saved
for me on Windows 11, Audacity 4 no longer saves the Stored Cursor Position When File Saved.
see Save Stored Cursor Position When File Saved
per “This topic will close 3 months after the last reply.” should i keep responding to myself until it is fixed? how does this work? thanks
Nothing gets fixed from comments here on the forum (unless one of the devs drops by and notices). You could go over to Gibhub, create a free account, then create a “New Issue” (green button) and make your suggestion (either as a bug [since it is a regression from AU3] or as an Enhancement Request).
Thanks for the report.
I’ve logged the issue on GitHub, you can track its progress here.
