Forgive me, this has to be one of the most frequent operations in Audacity, but I can’t find the right terminology to search out an answer (or maybe there is no answer!).
I’ve split a long concert recording into several clips. I want to save each clip as a separate file. I’m hoping there’s a better way than to:
Select each clip individually
Cut
Paste into new project
Save project
Audacity makes it fussy to select a clip (I can’t find a more efficient way than to position cursor inside a clip and choose “Clip Boundaries>Previous Clip Boundary to Cursor”, then “Cursor to Next Clip Boundary”). So to repeat the above procedure for 8 or 10 clips is 5 minutes of work. Since this is, again, something a lot of Audacity users must need to do, I’m hoping there’s a shortcut!
