I’m currently using an sE2200a2c condenser mic, attached to a Scarlet2i2 Focusrite 2x2 pre-amp. My computer is an HP laptop running Windows 7. My version of Audacity is 2.0.1. I’m recording a Mono channel at 48000 Hz, 24-bit.
As you can hear from the attached sample, there is a light ringing sound whenever the mic experiences a slight vibration, either movement or just my voice. It’s slight, but it is enough to be heard. Because it isn’t a constant sound, I have been unsuccessful in removing it with Noise Removal, and while I’m sure there is an editing component that could get rid of it, I’d rather it just not exist in the first place.
I have replaced the mic once already, used it in various parts of the room, used it on and off the mic stand. My input and output in Audacity are both set to the Scarlet Line and I have recorded with the volume on the Output on mute and full volume. The gain setting on the Scarlet is relatively soft (I had to Normalize the attached clip to make it audible). I don’t use headphones when I record, so there’s nothing else attached to the Scarlet but the mic and the cord to the computer.
I’m very new to audio, so there may be a simple explanation I have yet to try, but I’m at my wits end. Many thanks in advance for help!
Oh, that’s good. I would have guessed feedback, but if you’re wearing headphones…
So would we. Nothing quite like the posting that starts: “Can you help me clean up…”
No, probably not.
Just to cover the bases, it happens after you restart the machine and you turned off Windows Enhanced Services?
I need to dig through your equipment list and listen to it again.
It happens if you turn your headphones off, completely off? What happens if you tap the microphone with a pencil or tap two pencils together? I’ve designed my own microphone amplifiers and it sounds on first pass like your microphone amplifier is oscillating - singing – or just about to and anything at all can set it off. This isn’t unusual. A microphone amplifier has to be able to make a microscopically small signal (hence the name “micro-phone”) 1000 times or more bigger. To put this in perspective, that’s the difference between a flashlight battery and the high tension power lines that power your neighborhood.
So reading this carefully this time, you don’t use headphones at all when you perform.
It seems that everything is standing on the USB connection. Is that what you’re using for the show sound, or are you using the analog outputs behind the Focusrite?
The Focusrite gets its operating voltages (5 volts) from the USB connection at the laptop. The microphone gets its 48v Phantom Power from the Focusrite. That’s not a contradiction. There are chipsets that can easily get between any voltage and almost any other. They are welcome. Microphone technology was just starting to fragment into different Phantom voltages when that happened. We hope those oddball, non-48v, microphones never see light of day.
Is there any chance at all you can plug the whole shootin’ match into a different computer? Change the USB socket on your computer?
I’m on the edge of my seat for your posting of the pencil tests.
Here’s one. Can you make it worse? Is there anything you can do to make the problem awful?
Are you using a cable exactly like this, or are you going through adapters with cables you happened to have lying around. I’m concerned that in addition to your ringing sound, there’s also some power line buzz down there. I would not expect that in your system. So you may have two problems.
I’m generating increasingly exotic symptoms. If I amplify the ringing sounds in your clip, they also have, in addition to the tinkly bell sound, thumps and bumps very much like, (drum roll) a very unstable microphone amplifier.
I would go to great length to plug the Focusrite into a different computer.
It’s going to be difficult to tell where that whistling is coming from, whether it is the microphone, the pre-amp, or the computer, unless you are able to test each component separately.
To filter out the whistle you can use this code in the Nyquist Prompt effect:
It’s the second microphone and when the poster tries a different computer, that points to the Focusrite – assuming the problem doesn’t go away. If the problem does go away, then the USB on the laptop isn’t up to the task.
In that case, a single task, wall-powered hub may be the answer.
That’s not actually how I got the figure. I tried your 3901 Hz figure, then made the notch narrower and it left a sliver of a spike on the right hand edge of the notch. Shifting the centre frequency just a little to the right (a few Hz higher) was enough to catch both peaks.
My guess was 3911, not 3901. That’s one of the answers that Analyze > Plot Spectrum gave me, and yes, I suspected that there were multiple peaks from the odd behavior of the cursor.
So I just launched the Plot Spectrum Magnifier Tool and … Oh, wait. Plot Spectrum doesn’t have a magnifier tool.
I’ve just gone cross-eyed with all the tech jargon, but I will attempt to answer the questions. (And thank you for asking!)
I have yet to try another computer, I’m workin’ on that. I have plugged it into all of my USB ports on this computer, though (some of them don’t even work, but I think that’s an HP issue). Same problem with all working ports.
I have one XLR cable, a Blue 20’ Premium Quad Cable
I have restarted the machine, but I’m not familiar with “Windows Enhanced Services.” Please explain?
My XLR cable plugs into the front of the Focusrite, the USB cable comes from the back and plugs directly into my laptop.
I don’t know what all the number talk means, but I guess the takeaway is that I’ll try another computer and circle back with you when I know more. Unless you think that this “Enhanced Services” thing is a solution. Thanks!!!
I doubt that it is the solution, but this is what Koz was referring to: Audacity Manual
Sorry about that, we get carried away sometimes
The upshot of the “tech jargon” is that if you use “Plot Spectrum” (Audacity Manual) on the noise, you may notice a little spike at around 3900 Hz (it is actually 2 spikes very close together, but it looks like one spike). There is also another even thinner spike at around 7800 Hz, but this is quite hard to see unless you get the settings in Plot Spectrum just right. These “spikes” represent the frequency of the whistling.
The little bit of code that I posted is a very precise filter that will remove those frequencies, leaving the rest of the audio virtually untouched. To run that code, you would need to copy and paste it into the Nyquist Prompt effect (Audacity Manual). It does not fix the cause of the problem, but it does remove the symptom.
Let me read that back to you.
“The computer has known broken USB ports, but that can’t possibly be what’s wrong…”
I predict you’re going to plug into another computer and the problem is going to vanish. It’s still possible it’s the Focusrite, but it’s looking more and more like the USB service in the computer.
If the computer is causing the problems, there is a relatively cheap way out. Buy a wall-powered USB hub and put the Focusrite on that and the hub into the computer. The power to run the Focusrite and the microphone will then come from the hub and the wall, not the computer. The trick is you can’t use the hub for anything else. Don’t for example, plug a mouse into it.
Did the problem show up a lot better with the pencil test?
Thanks to you both! I will look at the Enhancement, try a pencil test, test a new computer and also look into this powered USB hub thing. Stay tuned. In the meantime, I’ll also try out Steve’s filter.
Interesting development: I bought the USB hub with A/C power, and there was no change. However, I also attempted to record on Twisted Wave online (I don’t have a Mac, so there was no other way of trying this software). And no ringing. At all. I have yet to try the test on another computer while using Audacity, but I thought this was an interesting wrinkle! More soon.
Finally. I tested the mic on a friend’s computer (also a PC, but not a laptop). Same ringing issue. I also tested an AT2020 USB mic. Same thing, albeit slighter. So it’s not a Focusrite thing, it must be an Audacity thing. Oh, also did the pencil test. That didn’t cause ringing. Just loud talking or very light vibration of the mic itself. I will attempt Steve’s filter, but any other thoughts?
I doubt that it is “an Audacity thing” because Audacity just records the data that it is given and has no ability to modify the audio data during recording. Anyhow, you could test that by recording a test using Microsoft Sound Recorder to see if the ringing still occurs without Audacity.
