what is the best app for mobile recording calls?
[link removed]
[link removed]
I don’t know that there is a good way to record phone conversations with an app.
I use a special microphone.
What’s your phone type? If you find an app that works, post back.
I use Cube ACR to record calls on Android 10. I think it only records sound directly from my own phone’s mic (it might depend on the “phone recording audio source” you tell it to use), so the quality is not the best. A special mic as Koz suggests would probably be better if you’re after higher quality audio.
Note: depending on where you live, recording calls may be illegal unless everyone on the call consents to it. I happen to live in a one-party consent state, where it’s legal as long as one party (me) consents to the recording.
