Really wish that i could make a palette
I really wish i could make a palette of fx I’m using, similar to repeat last effect, but with a palette of like 10? Different fx that i could access with a click… does that make sense? Should i draw a diagram?
You can build a Macro to do that - see here in the Audacity manual:
And see this section of the Muse Audacity Support site:
Peter
I thought macro was a sequence? And i can’t figure out how to even do that (create a sequence). I’ve tried so many times but i can’t remember what the problem is and I’m away from my device atm…
A macro is just a set of effects chained together, to be run one after the other automatically
  1. You can set the required parameters for each effect in the macro
  2. If you use the macro a lot you can set a custom keyboard shortcut for it - see:
Peter
Right OK that’s how i understood it. What i mean is a palette of fx to use at a click, interchangeably in any order. Just hanging out and available to jump in as i need them.
I seem to recall that for the version 4 of Audacity (no idea of the timeframe) Muse may well be considering a “Favorites” section in the Effect menu which would enable you to place your palette items there.
Meanwhile how about this for a workaround:
  1. disable all the effects that you don’t need for your palette, use Effect > Plugin Manager for that
  2. In Effects preferences set the “Effect menu organization” to be “Sort by effect name
If you later find you need one of the disable effects you can simply re-enable it (temporarily or permanently).
I did just this when I was digitizing my LPs and tapes some years ago when I didn’t need most of the effects.
Peter
