Professional sounding fade out.
Anyone who has been following this thread will be pleased to know that the Pro Fade has been committed as part of future Audacity releases. It is released under the name “Studio Fade Out”. It is already available for test in the alpha nighlties (it hit the 1Jan13 alpha release) - and will be in the upcoming 2.0.3 release.
Also committed at the same time was Steve’s Adjustable Fade - and Bass and Treble which replacess Bass Boost.
A big vote of thanks to Steve for developing these fades - an extremely useful addition to the Audacity toolkit for many of us.
Peter.
Topic moved to the archive.
Attached is the version that will be included with Audacity 2.0.3:
StudioFadeOut.ny (1.35 KB)
Oh okay I see… yeah you’re right. I’ve been thinking… I wanted the Pro-Fade reversed to fade in the low frequencies a little faster than the middle and high frequencies, much in the same way that a normal Pro-Fade fade out fades the low and then the rest. But reversed would do the opposite of what I wanted. Is there a way to fade in that brings low-frequencies faster? (applying a normal fade in 3 times doesn’t do it)
YES! Thanks, Steve - rest assured that I’m looking forward to using this very-necessary tool!
  • Win
That could be Studio Fade In, but I think Steve feels people have a variety of requirements from a fade in and that it would be better if the one-click-musical-fade-in to be applied could be chosen in a configuration tool.
Did you vote for a Musical Fade In New Fade Effects (poll) ?
I don’t know where the topic for Musical Fade In has gone now.
It’s still there but its on the second page right now
https://forum.audacityteam.org/t/musical-fade-in-effect/26964/1
Actually it’s coming rapidly up to the time that this would get transferred to Wiki>PFR - but I suspect that I shouldn’t do this - advice?
Peter
If you can figure out how many votes to add for (a) a one-click-but-configurable musical fade in (b) a one-click fade in that is the opposite of Studio Fade Out I think you could add the votes to PFR’s.
I think we want to archive this topic in any case.
You ROCK!
I was not sure how to add a plug-in so for those impaired by that simply drop the downloaded file into your (at least in my computer it is set-up this way and my was by default)…drop the downloaded file into PROGRAMS —> AUDACITY —> PLUGINS make sure you do not have audacity open or just close and re-open audacity.
Then, go in and open the Audacity program…go to “effects” then use the arrow to scroll up to “manage” you will see “new” files including the “profade” file you just put in there and you can click on it to “enable.”
Now, you go and select the last portion where you want it to end (usually :05-:10 seconds), then go to “effects” scroll down to the “profade” and wha-la!
This plug-in is quite amazing and it is my first…I do professional voiceover’s and so my audio of my script ends before the music does and I used to use the fade-out effect and just do it over and over and over until I got it sounding “good” but this is perfectly done in one-step! Awesome! Thank you so much!
Glad you like the plug-in TriciaLynn.
The current version of Audacity has this effect as standard, though the name has changed to “Studio Fade Out” http://manual.audacityteam.org/man/fades.html#studio_fadeout
Your effort in learning how to install plug-ins is not wasted, as there are many other optional plug-ins available, and I’m sure that you will find a need to install another plug-in sooner or later. :wink:
You could reverse a selection, apply the Professional Fade Out effect, then reverse it again
Wow, you are replying to an ancient post!
You can see my response to waxcylinder in this post: Professional sounding fade out. - #7 by steve
And Waxcylinder confirms that Steve’s solution of repeating the fade-in works a treat - I normally do a 3xfade-in
And to make my life easier I have assigned custom shortcuts for the Studio Fade Out and for Fade In
Cute trick that, pogo-stump :ugeek:
but I think I’ll stick with Steve’s suggestion of multiple fade-ins - it’s quicker that way :sunglasses:
yeah I stack fade outs on stuff all the time, especially on snares and hi hats
me too i’ve been slowly assigning shortcuts to more and more effects so maybe someday i won’t even need to use the toolbar haha
