I am somewhat new to Audacity (coming from Magix) and very much enjoy the work on version 4; lot’s of great stuff; thank you!
What I find super counterintuitive is that if pressing the “Play” button (or “space”), playback does not start at the current cursor position but at the beginning of a file. In my daily life this is almost never what I want. I found out that I get the desired behaviour by pressing Shift + Space, but in my eyes, this should be exactly the other way round. In the “Shortcuts” preferences section, I was unable to swap this, as both shortcuts (space / shift + space) were assigned to “Play” - another oddness.
Please let me know if I overlooked something. Otherwise, I would like to encourage a change here.
Ah, I just saw that I obtain the desired behaviour if I select “click ruler to start playback”. This is fine. I would still vote for making this the default.
I understand that this is the original audacity UX way. I do not understand why a drag / selection operation should be necessary for this, though. (Why do I need to specify an “end of playback” via dragging if I don’t care?) This was counterintuitive to me, and the same may apply to other users. Since playing from the start is a rare use case for me (and I think for most other users as well), this should be reflected in the defaults.
