Play-at-speed used to change the speed/pitch live. Now it doesn’t anymore.
Open Audacity, drag in an audio file, press Play-at-Speed, change the speed. It does not update to play faster or slower, you need to restart the playback.
This definitely used to work differently.
Looks like a regression bug to me - I’ll log it tomorrow (if no-one else gets there first)
Good catch,
Peter
Yes, it worked in 3.0.2, and is broken in 3.1.1 (Tested on Linux)
It’s a regression on 3.0.5
I suspect the new looping changes kiboshed it !
Peter.
Logged on GitHub as a P1 regression https://github.com/audacity/audacity/issues/2149
Thanks for the report AyCe
