Option to completely disable Loop System in Audacity ... :
Could a simple Disable Loop System be implemented in options, please?
As is, there’s no such option, and the darn thing continuously gets in the way copy-pasting parts of music … . :frowning:
It is possible, this is in Audacity, but I did not find such an option, and search engines do not help me either.
It was once in there, but no more … .
Thank you aforehand:
Xog.
The PITA looping system was introduced in Audacity 3.1
https://www.fosshub.com/Audacity-old.html
Marvelous, and this helps me how, please?
I asked for a Settings-toggle so I can turn the darn thing off.
Here is what the issue is:
Audacity 3.7.4 - Unable to disable Loop System …? - Audacity 3 Help Forum / Windows - Audacity Forum
This might clear the issue, described in that link, up … ?
