I compiled Audacity with OpenVINO on Ubuntu 22.04 following this readme:
Everything seemed to be alright, but I get an error when I want to use it:
15:43:40: Error: In Noise Suppression Compilation, exception: Exception from src/inference/src/core.cpp:85:
Exception from src/inference/src/model_reader.cpp:137:
Unable to read the model: /usr/local/lib/openvino-models/noise-suppression-denseunet-ll-0001.xml
Following the readme no noise-suppression-denseunet-ll-0001.xml has been generated, and I can’t select anything else from within audacity (from effect/openvino ai effect/openvino noise suppression).
and could have answered it, if this forum wouldn’t automatically close topics after 30 days (what seems ridiculously short)
My answer is: the whole thing (git-clones, audacity, openvino and openvino-models etc) is 11.2 GB
Ah, okay. Sorry about that… we’ve been refactoring that README with the instructions to pull models directly from hugging face, and elsewhere (like open model zoo in this case). Let me update the README that shows how/where to grab noise-suppression-denseunet-ll-0001.xml.
Download those, and drop them into the openvino-models folder.
As a side note, I’m currently working on integrating better quality & faster models (deepfilternet2 & deepfilternet3) into the project… should be merged next few days, so stay tuned.
