Odd distortion
I’ve just started the process of digitising my 12" vinyl collection, and have run in to some difficulties with getting consistent high-quality results.
I am using a Technics 1210 with Stanton 500 cart. This is currently being run through an Intimidation Blue DJ mixer in to an M-Audio 2496 PCI sound card.
I am recording a variety of dance music, from ambient to techno. The issue is that on some tracks the bass sounds very distorted on playback. The live input sounds fine on these tracks during playback, and I’ve experimented with the mixer’s gain controls to try and eliminate the problem. Even with the gain right down on the mixer, I still get really poor quality on some records, despite sounding great when heard directly.
Where am I going wrong? :frowning:
Are you listening to the mixer or the computer?
I can’t find any technical information on the mixer. Does it have a Tape-Out? Sometimes the Tape-Out is isolated from the final mixer controls and the volume doesn’t go up and down like you think. Tape-Out also sometimes bypasses the equalizers and special effects.
Did the sound card come with software to control volume? Do the controls show up in the Windows Control Panels, or is it a separate application?
I’m listening to the computer. The mixer was a fairly decent one when new (15 years back). I’m running the master output to the sound card. I’ve tried altering the software levels to no avail. The sound card has no gain control as such.
OK, I’ve installed and tried a different software recorder and found that I have a similar issue. I guess this points a finger at my hardware/recording technique. As I mentioned before, the audio sounds fine when listening to it through the computer as I’m recording, it’s only in playback that the distortion becomes apparent.
could you be clipping the bass booms when the drum gets hit?
my first thought was your cartridge was tracking too lightly but if it sounds good going in and bad on playback i am thinking you are clipping. record low for plenty of headroom. you can make it louder after you have it recorded right.
are you using an riaa curve to fix the levels that are recorded?
does the mixer have that option? does the sound card ??
are you doing any f/x processing?
<<<are you using an riaa curve to fix the levels that are recorded? >>>
That’s built into the mixer. The sound delivered to the system is flat and undistorted.
I think that’s what he’s trying to do.
This is a perfectly recorded piano solo…
http://kozco.com/tech/audacity/Audacity1_playback.jpg
Your bouncing light meters may look different. Note the blue waves never reach “1”, either wave, either direction. You’ll need to take my word for it that the bouncing light meter never goes to maximum.
If your waves look like that, then you have a perfect recording and the problem is listening to it. If your blue waves constantly smack “1” or worse yet, turn red, then yes, the recording process is messing up.
Did you try reducing the Audacity recording level with the little microphone slider?
I’ve tried adjusting the various levels within Audacity to no avail, even recording with minimal levels, the distortion is still there. I’m gettign more convinced that this could be a hardware issue, but I can’t think what. I’m going to try a different source tomorrow, both direct to the sound card and via the mixer. The issue was present without the mixer, when I used a Behringer PP400 Phono Pre-amp - this gave me no hardware gain control, so I figured at the time that was the issue - too much gain. I’m beginning to think the issue is with either the PC itself or the soundcard. I’m going to try moving the card to a different PCI slot as well.
Have you tried burning the recording to audio CD and playing on a CD player? This would serve to eliminate the possibility that the distortion is produced by computer playback.
Yes, I’ve tried burning to CD - the distortion is still present.
<<<Yes, I’ve tried burning to CD - the distortion is still present.>>>
You need to work with us. Shortcuts don’t work well when we’re troubleshooting.
And you played the CD on Something Else? Not the same computer?
Do the blue waves have a lot of even tops and bottoms like somebody took a ruler here and there and evened them all out? I don’t have an illustration for that. Sorry.
My piano solo has a lot of uneven spikes and valleys and no obvious flat spots except at the beginning and end which is normal.
Here. I intentionally damaged a sound file…
That peak flattening is most unusual in a sound file and creates very bad distortion.
Apologies, didn’t mean to sound snappy :slight_smile:
I’d burnt the CD a little while ago to play the tracks in my car, which is when I first noticed the problem (as I’d not listened back to the tracks on my PC before playing the disc in my car).
I know what you mean in terms of the tops of the wave forms flattening out - as though they are clipping.
Here’s a snip of a recording I’ve just made:
This is a close-up of one of the drum beats where the distortion is obvious:
I’m not sure how I could upload an audio clip so you could get an idea of the issue first-hand.
Could you post a bigger picture of that second image. There appear to be some odd little spikes but I can’t quite make it out.
Short (less than 1MB I think) MP3 or WAV files can be uploaded when you are making your post - look for the “upload” tab below the message compose box.
A short audio sample would probably be better than another picture.
Apologies for the delay, here is a single drum noise, recorded normally. It sounds fine ‘live’ but distorted on playback.
The original image can be viewed here: http://www.flickr.com/photos/julianhj/4502330375/sizes/o/
It’s those little spikes that are the problem - that is not normal at all.
It isn’t caused by “clipping”, but looks more like data corruption.
It’s difficult to tell if the spikes are evenly place - they look to be around every 400 samples or multiples of that - possibly bad RAM buffering the audio input? Other ideas anyone?
That’s looking like a possibility. Have you tried that yet? If it’s easy for you to do then I think it’s worth testing.
Has anyone mentioned sound card drivers yet? Driver bugs can cause all sorts of weird problems - if you’ve not done so already, check that the sound card drivers are up to date.
I moved the sound card to a different PCI slot today, and the computer refused to see it - I assumed it would have to be completely reinstalled, so moved it straight back.
I checked my M-Audio driver, and it’s up to date. I even unplugged and dragged my AV receiver up to the study to see if an alternative method of pre-amping would solve the issue. It didn’t.
Plan B is about to be implemented - the purchase of a NAD PP3 phono pre-amp. This has a USB output, so not only can I by-pass the M-Audio card, I can also exclude my aging desktop from the equation and use my much newer laptop. It does initially mean I lose the gain control if I go deck > NAD > laptop, however the NAD also has a line in. If the ‘soft-clipping’ of the NAD’s DAC proves a problem, I can run he deck through the DJ mixer to maintain gain control.
Thanks for all your responses so far, they’ve stopped me tearing my hair out!
Maybe, but maybe not. I always used to think that with a USB device like this connected than you lost the ability to use the software gain slider in Audacity. Cetailny this was how my earlier ION iTTUSB behaved and how my external USB soundcard (Edirol UA-1EX) still behaves.
But I am assured by Gale Andrews that with some USB devices and the correct drivers then the Audacity software input gain control will operate. He assures me that his later ION TTs work this way.
He believes that my inability to use the input slider in Audacity is possibly down to the fact that I use my Edirol with the Windows supplied drivers - and that if I installed the Edirol drivers then the slider should work. I am reticent about trying this as my current setup works extremely well and I am loathe to change this - I don’t need the software gain control as I have hardware gain controls both on the Edirol soundcard and on my phono pre-amp (I use the ARTcessories DJ-PreII). I did consider the NAD PP2 (which is the OO£ but without the soundcard&USB) on my shortlist when I was buying, but the lack of gain control put me off. But the NAD certainly looks to be a good piece of kit.
Once you have implemented plan B and got the NAD working with Audacity perhaps you could contribute a brief review of the device in this sticky thread we have re. soundcards that work well with Audacity (which Stevethefiddle started a while back): https://forum.audacityteam.org/t/sound-card-reviews/8375/1
It’s not clipping or flat-topping. That’s serious data distortion. It’s not just the spikes, either. Look at how some of the graceful up and down progression of the waves is interrupted like someone took a razor to it. Look about 5.150. That’s apart from the spikes which are very serious.
I’m just looking closely. There’s several of those discontinuous offsets. There’s another one at 5.190 and then again at 5.215.
That damage happens at a different period from the spikes. So there’s two data errors.
If I had to guess I’d say faulty sound card, though I’d like to test it, either in a different PC (preferably with a different OS) or in a different recording program using ASIO drivers (preferable on a different machine).
