Need help saving wma files, adds extra 2 seconds
I’m currently running 2.0.5. Perhaps I should update. But when I go to save before the layout changed), the song when saved lists the correct duration, 3:39. However when I save, it adds a extra two seconds to the song
On W10 with 3.6.4 I tested and I get a very slight decrease in the audio length
  1. Generate a 30 second chirp
  2. Export as WMA (with default settings)
  3. re-import the WMA file
  4. Observe: the imported chirp is 0.046 seconds shorter at 29.954 secs
I repeated the test with a one hour chirp and the re-imported WMA chirp was 59mins 59.975secs long i.e. shorter by 0.025 seconds
Peter
