Hi. How do you make the music fade at the end so it doesn’t just cut off abruptly? Thank you!
Select-highlight the part you want to fade-out. It may help to zoom-in.
Then Effect → Fading → Fade Out or there are a couple of other options.
Effect > Fading > Studio Fade Out
give a more pleasant musical, “professional” , fade out.
Peter
Thx for the response! I’m still having some problem, I think it is with selecting the portion I want to fade out. I am just dragging across it to select it. I tried using the “select” dropdown but I don’t understand any of the choices there. But when I drag to select, then go to Effects, the fade texts is not active, doesn’t do anything. I assume that means I don’t really have a region selected?? Can you help, please? Thank you!!
I think I got it, thx! It’s not fading out as gradually as I would like but it may be the limitation of the music piece itself.
