Multi-View is very cool.
Can we please have a setting that enables it by default (just like we can pick spectrogram or waveform as default currently)
I already responded to another user who wanted this.
I logged it on our Bugtracker as Bug #2460
https://bugzilla.audacityteam.org/show_bug.cgi?id=2460
Can’t select “Multi-view” as default view mode in Tracks preferences
But glad you’re liking the Multi-view.
Peter.
Still can’t do this, in 2025. I’d really like it as a feature!
I am certain that I have my Audacity set to default to multi-view when an audio file opens. I know this because when I am going to be opening some very large files I will disable it first because it takes much longer to load them with multi-view turned on.
Ahhh!.. It exists!.. Edit → preferences → Tracks → Default View Mode.
On my Mac running version 2.4.2 I can only select either Spectogram or Waveform in the default view mode preference. I’ll update it and see if that changes…
Updated and got the option thanks! Didn’t realise my version was so old!!
