For weekly audio recording projects of similar nature to be exported into MP3s:
IHow to pre-fixing the file name with Audacity automatically filling the date into the chain, with the same pre-fixed option, e.g. file name, directory, file parameters etc (44Hz; 33bit; mono?)
Can we record a macro for Audacity of the purpose?
a) for a start the daye and time come after the trackname and don’t prefix it.
b) what you can do is to use File > Export Multiple and choose the option to export by tracks rather than labels (nut you will need more than one track for this to work - so you may need a dummy track that you can delete after the export.
