Mix and render to new track, would like it to omit muted tracks
Scenario: I have a few dozen tracks, and I have muted a handful of them scattered here and there. I would like to see my project mixed to a single track. If I want to use mix and render to a new track, I have to scroll up and down deselecting all my muted tracks. If the Mix-and-render respected the MUTED setting, I would just (Ctrl-A) select all tracks, and get the desired result.
As it is, I can get the desired result in two steps
  1. export to WAV,
  2. import the WAV file…
    It’s not really difficult, but it’s a little clumsy. And I suspect there’s some clever way to do what I want anyway.
I just tried to reproduce this case. Indeed, such a bug appeared in Audacity version 3.6.1. You can select all tracks, then unselect muted tracks and mix selected (unmuted) tracks
I don’t think this is a bug, I think it is intended behavior. It’s certainly not a regression, I just tested on various old Audacity versions back to 2.0.0 and the same behavior obtains - and even in 1.2.6 too.
What Mix and Render does is to mix all tracks that are selected.
The manual states that this is the case:
Admittedly it doesnt say that muted tracks, if selected, are also included - but I can, and will, fix that for the alpha manual for the upcoming 3.6.2 release.
@bdbmkeeirsk11
Your workaround of exporting as WAV and reimporting to avaid muted tracks is a great workaround.
I think I may file an Enhancement Request for Mix&Render to exclude any muted tracks. - I just discussed this with my “Mystery-Shopper” and she agrees.
Peter.
The 3.6.2 will now make this behavior clearer. In the alpha manual it now says
Peter.
It does here in the blue box at the top: https://manual.audacityteam.org/man/mixing.html
All selected tracks are mixed, regardless of the Mute or Solo buttons
Thanks @steve
I also just added this to the into in the alpha manual for greater clarity.
Peter
I understand that this behavior is built into the program, but this is ridiculous behavior. When a user has muted certain tracks, they expect this to be reflected in the resulting mix. But no, these tracks need to be “muted” again
Yes, I am minded to agree with you.
And that’s why I said I would be submitting an Enhancement request for Mixing to omit muted tracks.
But first I have to update the alpha manual for 3.6.2
Peter
@steve
Thanks again for tha link to “Mixing Audio Tracks”.
That page needs some updating as it does not explain the difference between explicitly Mixing with the Mix commands (which does include mutes) and implicit mixing with export (which does not include mutes).
I can fix that.
I also added a link in the “Tracks Menu: Mix” page’s intro div to the Mixing page:
Peter
I recall some years ago, this question being discussed at length by the developers. My position at that time was that “Mix and Render” should behave the same as mixdown on Export and ignore muted tracks. The opposing view is that Mix and Render should act on all selected tracks and ignore whether the track is muted or not, consistent with applying effects regardless of the track mute status. The latter argument won, mainly because that was how Audacity had always worked and long term users would be expecting Audacity to behave this way.
@bdbmkeeirsk11 @VP2024
I have added this Enhancement Request
@steve
You will see that I incorporated your valuable feedback regarding the history of this. Many thanks for that.
Peter.
The “powers that be” at Muse (Design-focussed people) have acknowledged this Enhancement Request and it looks like we might get to see this later in 3.7.0
Peter
Thanks to all for the enthusiastic and thorough responses!
