Hello guys. Could you tell me what the plugin for Audacity is working like Click/Pop Eliminator on Adobe Audition? Cant find it by myself. Click/Pop Eliminator works very well to me but i want to use just Audacity with no Adobe Audition. Thank you.
Please see this page in the Audacity Manual: https://manual.audacityteam.org/man/click_removal.html
Also see this free Audacity DeClicker plugin … https://forum.audacityteam.org/t/updated-de-clicker-and-new-de-esser-for-speech/34283/1
You won’t find anything EXACTLY like the Audition effect. All of the click & pop removal tools are different. It’s difficult and “complicated”, and there are compromises.
In Audacity, you can use the manual Repair effect, or as a last resort zoom-in on the defect re-draw the waveform. (The Spectrogram view is usually better for zooming-in to “find” the defect. Then you can switch-back to the normal waveform view.) For “regular noise”, such has low-level background hiss you can use the regular Noise Reduction effect, or the Gate effect (noise gate).
Izotope RX (not free!) has a very-good good reputation. (I don’t own it.)
There are special-purpose programs for removing vinyl clicks & pops (and these sometimes work on other short-duration defects). I’ve used [u]Wave Repair[/u] ($30 USD) for a long time, but it’s not automatic. That means it only “touches” the audio where you identify a defect and you can try multiple repair methods and choose the best one for each defect. But of course it’s VERY time consuming. [u]Wave Corrector[/u] is fully-automatic and it’s now FREE! [u]This page[/u] (from the Wave Repair developer) has several other suggested applications for “vinyl clean-up”.
