Windows 7, 32-bit here. The newer Audacity versions for my operating system come with many changes that are not always for the better. I appreciate some, however, and since I haven’t kept my eye on which changes which versions have brought, I would like suggestions on the most acceptable version to downgrade to - something before the most odious innovations but preferably with some good ones already in.
Things I hate the most:
It is impossible to click in the beginning of a track. The mouse cursor simply won’t go there. One has to click somewhere early in the track and use the left cursor key to slide to the start.
Having to use Edit → Join audio to merge inserted track pieces.
Having to select a portion of the track or the entire track to apply Amplify, Bass and Treble and other effects. In some version, possibly quite an early one, the entire track was automatically selected in the absence of a custom selection. It would be good to roll back to that, if this would not leave me with some antediluvian version.
If possible, return automatic back-ups of previous namesake files. They were a bit of a hassle to delete afterwards, but sometimes very useful for going back to a better edit. But it’s possible that this remains an option somewhere.
Things I would like to keep:
The new Export Audio system that does not force one to open the target directory. Everything happens in one window here.
This is probably it. There are a few small conveniences here and there that I approve of, although they clutter the screen and are not necessary. Car doors could have buttons for “Lower screen down by half” and “Open window a chink,” but it’s not a good idea.
