Just updated to 3.7.4. What happened to Swap Channels option in Edit menu?
Just updated to 3.7.4. What happened to Swap Channels option in Edit menu? I often swap channels for a selection. Need to restore this function.
It’s not in the Edit menu and never has been, as far as I can recall - it’s in the Track Control Panel dropdown menu:
Left-lick on the ellipsis (three little dots) - or right-click on the blank space of the TCP to get that menu
Peter
Thanks for the reply. That menu only applies to the whole waveform. I want to swap channels for selections within the waveform. Was able to do that before. It’s OK, tho. I found another program that will do that. Just prefer using Audacity.
