- File > Import > Audio
- I imported the song “Cool for Cats” by Squeeze
- I selected the chorus section of the song and cut it out
- Tracks > Add New > Stereo Track
- I copy and pasted the chorus section onto the new track and deleted the original one
- Tracks > Stereo Track to Mono
- I selected the audio
- I went the the “Effect” bar and clicked “reverse”
- I then selected “Paulstretch” in the “Effect” section
- I set the “Stretch Factor” to 10 and the “Time Resolution” to 0.25 seconds
- I then used the envelope tool to gradually decrease the volume at the end of the track
- I also used the “Studio Fade Out” effect to make this more extreme
Cool
Would make the good basis of a sound-track for SCUBA diving videos (would make a great change from the ubiquitous Enya stuff that most diver videographers used a few years ago … )
And this is me writing that “recipe” down to try it later on other tracks
Enya-fication of any music is possible with a VST plugin called DTBlkFx …
Enya-fier.xml (479 Bytes)
Suggestion : apply Paulstretch on default settings (10x 0.25s) after Enya-fication.
