Imported flac files played back with different pitch after update to 3.7.5
After updating from Audacity 3.7.4 to 3.7.5 on windows 11, my Flac-files that I imported into a new project sound weird, like they are being played slower or distorted. The playback speed is set to 1, fiddling with the speed just makes the files sound weird differently, so I guess it’s not the playback speed. I haven’t got a clue what else it could be. The files are played correctly in the MS Media Player.
I tried the following fixes:
  • Reset configuration
  • Uninstalled 3.7.5 completely, restarted the PC, deleted the audacity folder in program files and reinstalled 3.7.5
    without any success.
So I went back to 3.7.4, which plays the files without any problem.
(I did download 3.7.4 from sourceforge, the page Old Audacity versions download linked in the troubleshooting section only has up to version 3.7.2)
Here’s the details of my Windows install:
Edition Windows 11 Pro
Version 24H2
Installed on ‎18/‎11/‎2024
OS build 26100.5074
Experience Windows Feature Experience Pack 1000.26100.234.0
@aloyse6 testing on W10 with 3.7.5 I cannot reproduce this.
I exported a know track from 2.4.2 as a FLAC and then imported it into 3.7.5 - and it played absolutely fine in 3.7.5 - exactly the same as it sounded when played in 2.4.2
Peter
Thanks for testing, Peter. Since you’ve tested on W10, I suppose that this is a W11 problem. Is there anything else that I could have done to try to fix this on my side?
My files are aircheck files from my monthly community radio show, I use Audacity to join those half hour files for a podcasts file and remove silences. The first step is always to import the files and listen to the first one to find the start of the show and cat the rest of the previous one. I did test with several different flac files from this year, none of them were played correctly in 3.7.5, they did work in the previous versions, which I knew, since I did make the podcast files every month.
Sorry I can’t test on W11 right now (I do have a W11 laptop but it lives in Zurich and I won’t be back there till mid November).
And sorry I can’t think of any settings that may have affected this.
Do the FLAC files sound ok if you play them again in an earlier version than 3.7.5?
Peter
The files sound fine in 3.7.4, or in any other media player, it’s just 3.7.5. I guess I’ll stay on 3.7.4 for now.
Hi Aloyse6 i have the same exact problem as you but it only happen here on audio flac that are 16 bits! all my 24-32 bits work perfectly so i dunno what they change in 3.7.5 but that what cause the problem (like they don’t take 16 bit flac into consideration anymore) try it and let me know if you have the same result.
Audacity 3.7.4 says after importing that the format is 32-bit float point, I have no software that shows me this information for the saved file, what can I use to see this?
MediaInfor online. Or you can install MediaInfo on your computer.
…Yes, by default Audacity works at 32-bit floating point internally and everything gets up-sampled.
Ok but that still don’t solve the problem! any solution to fix that in 3.7.5 of i have to revert back to a priors version?
Thank you for the link, DVDdoug.
The aircheck files are 16 bit, so that seems to be the problem.
I’m staying on 3.7.4 for now.
I have posted a bug report on Github.
