I can't find the chains library!
Hi folks,
I’m running OS Mojave on mac. I’ve been asked to send a chain file on to a friend but I can’t find where it might be saved. To make clear - I’ve never used a chain before and I’m just learning about them. I searched in my mac’s Terminal for ~/Library/Application Support/audacity/ but the result says there’s no such file or directory. Is there somewhere I can find it or someway of saving it out from Audacity itself?
Thanks :slight_smile:
Depending on which Audacity you have, chains is now called "Macros"
I’ve never used either one, but can’t you Drag-Select the programming and copy - paste to a text file? Desperation method is screen capture and send it as a picture. Shift-Command-3 the whole screen or Shift-Command-4 and drag a fence around the work.
Here it is.
https://manual.audacityteam.org/man/macros.html
To get to the audacity settings folder, follow steps 1 through 4 in this post: https://forum.audacityteam.org/t/resetting-audacity/50613/1
– Bill
Thank you all for helping - much appreciated! I found it in the end :slight_smile:
