How do i join together clips to one?
When you Export your finished project to make an audio file (WAV, MP3 or whatever), the clips are automatically merged into a single file.
http://manual.audacityteam.org/o/man/file_export_dialog.html
If that does not answer your question, please make your question clear.
Thank you for the answer.I have 5 clips short music ,i want them to bee one.I dont understand how to do it.Inger
- Open a new Audacity project
- Import the five audio files
- They weill be stacked one anove the other
- use Ctrl+A to select the whole project
- use Tracks > Align Tracks > Align End to End
- they’ll now all be in separate tracks - but arranged one after theother in sequence
- Export the entire project to a new audio file in your preferred format
You may wish to be more sophisticated and overlaps the beginning/ends of tracks and using crossfades.
