I have the latest version (I believe?) of Audacity, 2.0.6
I am running OSX Yosemite version 10.10.2
I recorded a voice memo on my iPhone and the battery shut down so I believe the recording did not save properly. On my iPhone the file shows as 00:00 in length however the file itself is over 540MB. I transferred the file to my MAC via USB cable through iTunes and saved to desktop. I also transferred a much smaller recording which did save properly.
After following some videos on YouTube and on this forum, I tried importing raw data in Audacity and mimicked the settings I found in the smaller recording, which was 16bit PCM with sample rate 22050 Hz.
However after trying this, the file still only opens as static. Is there anything else I am missing to be able to access this audio recording?
