How to fix or listen to broken m4a voice memo file
The native player appears to be Quicktime, but quicktime as a standalone program won’t open the exported files. Strange
Everything appears as either iTunes or QuickTime if the Mac can’t figure out what to do. iExplorer is not an Apple product:
Copyright © 2015 by Macroplant LLC
Macroplant LLC
114 E Louisiana St Ste 206
McKinney Texas 75069
support@macroplant.com >
It’s natural to just use QuickTime Services for everything, but you don’t have to. For one thing, historically, QuickTime will not recognize Windows Media files. See Flip4Mac:
http://www.telestream.net/flip4mac/overview.htm
You can contact MicroPlant to figure out what happened.
Since importing raw data in Audacity only resulted in static, the issue could be that the file’s structure is broken. You might have better luck repairing it using a specialized tool. I found this guide that could help: https://news.mаcgasm.net/tips/repair-m4a-file/ . It provides methods for fixing corrupted m4a files, which could be exactly what you need. Another thing to try is opening the file in VLC Media Player to see if it can recognize any playable data. If VLC plays even part of the file, you could try converting it to another format. Also, some audio recovery tools are designed specifically for extracting data from damaged files
You hijacked a 10-year-old thread… Congratulations!
wow what a blast from the past lol
