How To Downgrade from 2.2.2 to 2.2.1?
Okay, so I really kinda hate the new update for audacity. I much prefer the last version and was wondering if there’s a way to downgrade to it. I’ve looked around and all the links that say they are for 2.2.1 bring me to the same screen for the 2.2.2 download. Is there a way to find the 2.2.1 download for real or am I stuck with this update?
Thanks.
Also I hope I posted this in the right area, I literally just made an account and have never posted before. So if this is wrong, please tell me! Again, thanks.
There really are very few changes between 2.2.1 and 2.2.2, except for a few default settings in Preferences (which you can set as you prefer), and a nasty bug in 2.2.1 which can erase parts or all of your project (fixed in 2.2.2).
If you really want to go back to 2.2.1 (and I would strongly advise against doing so, because of the bug), then you can get it from here: http://www.oldfoss.com/Audacity.html (scroll down the page and select 2.2.1 as the version, then click the appropriate link).
And if you do downgrade to 2,2,1 or 2.2.0 then just make darn sure that you don’t use File > save As to save your project back to the existing open projec’s name - instead always use File > Save or its shortcut Ctrl + S
otherwise you are extremely likely to lose your project due to the serious bug that was introduced in 2.2.0, only spotted in 2.2.1 - and was fixed for 2.2.2
See bug report: http://bugzilla.audacityteam.org/show_bug.cgi?id=1811
Would there happen to be a list of these default settings that have been changed?
Here’s the list: https://wiki.audacityteam.org/wiki/Release_Notes_2.2.2
Poor Audacity forum admins. Spam must be horrific since I can’t even edit my post.
And this page in the manual: https://manual.audacityteam.org/man/new_features_in_this_release.html
We generally prefer that users don’t edit their previous posts (other than correcting typos immediately after posting), even when they have sufficient forum privileges to do so, because it can make topic threads impossible to follow.
Exceptionally it can be useful to correct errors in previous posts, but in such cases, please also leave a note of what has been corrected and why.
Note that the message composing screen has a “Preview” button, which allows you to check your post before posting.
